Ok, so I'm thinking about making a custom fiberglass box for my Kicker s10l5, which would be on the right side of my car in that little nook that goes in where the jack is hidden. I've read some other posts, and done some searching, and I was just wondering if you think this fiberglassing method sounds fine: I would be buying the mat and resin at the autozone near my house (together it all costs $10-20), then I would be laying tin foil all throughout the trunk of the car, covering everything so I make sure not to get resin on the car, then I would lay the fiberglass, and I would make the front flat with mdf board so I have a flat wall with the sub and it grille in it. Then I'd sand off the tin foil after doing several coats of the fiberglass and letting it dry (dries between coats too).
Let me know if you have any suggestions, or any pics of a p5 trunk with a similar box.
Thanks!
-DaViper
Thanks!
-DaViper
