External Temperature
2019 CX9 GT Pearl
Has anyone found a way to display the outside temperature, vs. passenger temperature, by default?
Currently the display reverts to passenger temperature setting whenever the vehicle is turned off. I'd like the display to always default to outside temperature.
My 2010 shows outside temp UNLESS I have ac/heat set to dual. Then it shows passenger side setting. I hardly ever use the dual controls. Now the rear controls are a whole different matter. I let those in the back fiddle with the temps to their hearts desire. Hope this helps.
2008 must function different than the 2010 models display.
On my 2008 I must push the lower half of the right hand front passenger control dial to display outside temperature every time the key is turned on. Not a problem, but a nuisances pet peeve.
Thanks for the input and replies.
Same for 2009.
