So far i'm going towards Cobb catback and either catted DP or cobb DP. Can someone tell me the difference between those two DP? Any other suggestions will help a lot.
Thanx
cpe or cobb both make nice downpipes. cobb only comes catted...cpe gives you the option to run catted or catless.
indeed cobb is no longer producing the cbe, so get something else
If money is an issue just buy the cobb dp and keep the stock cbe. Cobb'c cbe quiter than the stock exhaust so id say remove resonaters with the dp and see how you like that. Also Turbo XS is an option JSCspeed.com has the dp/rp combo for just over $300.
yeah, why spend the money for the cbe?
spend some money on things that will get you power or that will allow you to put the power down (mounts)
cbe is just for sound.
dp, some mounts, maybe a rear sway, possibly some traction bars...
an intake, an inlet...some other stuff...
no cbe
and if you must have the sound just cut the resonators out and it sounds like half the catbacks on the market difference is you'll spend 100 bucks at most
