Silver Ecstasy
- 11 MS3 Sport
Yep, i've got it logging RPM, absTPS, actAFR, Boost/Vacuum, WGDC.
Let's help get Silver to the bottom of the boost loss issue. That has nothing to do with a tune on his modest mods.
If he does not have a DH, then I hope he has or will install an inexpensive manual boost gauge. Since he did have some boost data, I assume it's from that gauge. Hopefully, tightning the tube clamps solved the problem.
Hell, I don't have a tune and don't really see the need for one for my particular use of my car, even with a catless dp/rp.
If you guys with tunes are running quicker than 13.4's at 106-107 on stock tires, and hitting 60-100 quicker than 6.3 seconds, let us know. Don't give me dyno numbers. Give me ET's and trap speeds. Give me some stopwatch timer numbers. That's literally where the rubber meets the road. On the open road, I can run with Cayman S's (to their considerable surprise) and the like and that's good enough for me.
I prefer to stay pig rich and have all the stock safety measures in place, including cold weather fuel cut on the stock tune, rather than pushing boost too far or risking leaning out the engine for just a few extra hp. I don't want to go around constantly worried about whether my tune took everything into consideration to keep me safe.
I have nothing against aftermarket ECU map changes and applaud those who get deeply into this and do it safely. But you'd be amazed at how accomodating and safe the stock ECU is for sensible mods, even up to catless dp/rp and the approx. two extra pounds of boost that brings with it.
Back to Silver: Did the tube clamp tightening solve the leak? If a gauge is still showing boost loss early, I have another couple ideas, one still on the intake side, the other with the fuel system.
Nobody could reply my question??!
replacing the cat back from the stock cat back doesnt net you much in the way of tq/hp. i think the net effect on your clutch is minimal...but if it is slipping already its going to still slip with the CBE(drunk)
Thanks for your reply
I need to reduce my boost...
Maybe your investment should be on a new clutch and not exhaust.Thanks for your reply
I don't understant why everybody says that there's no gain with a catback.
I couldn't find a dyno before / after!
You should get some hp in higher rpm...
Why would you think that? The stock CBE has a flow rate higher than the flow rate from the exhaust side of the stock K04 turbo. You can't flow more than the turbo puts out. The stock CBE is that good.
That's the reason there's really no gains to be made from CBE if you are running the stock turbo. Now, the downpipe and race pipe sections are a totally different thing. Both are highly restrictive and form a bottleneck between the turbo exhaust side and the CBE. That's where you can pick up some serious power with a properly bell-mouth shaped downpipe and either catless or high flow catted dp and an open race/test pipe connected to the stock CBE.
CBE changes when running the stock turbo should be for a change in sound, without any expectation of power gain, because it ain't gonna happen that way, IMHO.
BTW, responding to your earlier post question: If you go with the CBE, it will not likely raise boost because it does not increase flow. Aftermarket dp/rp will raise boost by eliminating the restrictions. Expect about 2 psi increase from eliminating the bottleneck.
