So finally starting to get all these kinks worked out on the MSP, however I am still having the bucking issue. I have had the fuel controller in it before, just havent had the time to put it back in as of yet. Weird thing was that it was still bucking (less) even with the fuel controller. I have a horrible exhaust leak that needs to be repaired and was wondering if that could be causing the issue since it is before the o2 sensor (or at least someone told me.) The leak is about fist size in the flex pipe.
I have new plugs, wires, coil packs, put a high flow air filter on and have the temp sensor installed right before the filter. I used to have my fuel controller installed, however I took it off to bring the car to the shop (warranty reasons.) My plugs are also gapped correcty and are not the stock protege gap.
My bucking issue seems to happen worse when it is colder outside. I do have another leak coming off of my intercooler pipe leading into my throttle body. It is a slight leak but still noticeable when hooked up to an air compressor. Any guidance on what to fix next? I have the universal intercooler piping kit, I just need to have time to install it. Also the piping kit that i purchased was 2.5 inch, is that correct? Thanks for reading.
Also compression test is:
176
168
189
171
The mechanics said it was ok. Hopefully this is correct.
176
168
189
171
