I noticed the same thing.. I used a die grinder and cut off the hangers... then i took off about 1/4 inch, rewelded and it worked.. Still has issues with the rear but im going to solve it when i find a better tip to weld on there.
How do you like the sound? Mine didnt come with the resonator, did yours?
CP-E had mentioned to me that they were going to come up with some more sturdy hangers. But then haven't gotten back to me on that as I was looking in to the same thing. Although the stock hangers work just fine.
yeah well i wasnt about to cut and weld anything when i was installing this because Jeff (from GHL) swore to me that it would be fine the way it was.
I was talking to my friend that helped me with the install about it, he has the GHL turbo back for his GTi and had the same problem. He found some shorter, stiffer bushings that really solved the problem...so im looking for reccomendations on those.
and I love the sound. There is no resonator. I see you have the PG test pipe, what do you think of the system without that cat?
Its actually not as loud as i thought it would be, but boy does it growl dude! You going with the racepipe? Serious torquage!
i love the growl now, i can only imagine that it gets better when you open it up! Yeah i really want the race pipe, but I'm saving up some funds for a new truck, so that and the upgraded top mount are being put on hold....for now (glare)
