Escape vs OEM
boyirish6
Mazda Protege5
I am sure this has been touched on will there be issues with the difference in lenth of the sway bar links. Looks to me there is a 1/2 inch differnce between the 2 of them. Any issues I have to worry about? I went and did it any way and bought the Moog escape awd 4x4 links.
^^ Agreed. I recently replaced mine with ones from Autozone, they mere Moog brand with grease fittings and they fit perfectly.
i just replaced mine last weekend. i thought the moog endlinks were slightly shorter, but i didnt measure..
anyway, i didnt have any trouble putting them on (aside from that freaking backward facing bolt on the bottom) !
also, a tip..i would recommend that you lube them up before you actually install them. i found the top one to be difficult to lube after they were on because of the way the nipple sticks up and hits the wheel well.
They are slightly shorter. I did mine with the same from Autozone. They were Moog Branded and also had the grease fittings.
