goodday guys not sure if this is the right forum for this but i'll ask any way having a problem with my Bj RSS it has the 1.5vvt engine with the activ-matic transmission its a J-spec vehicle but recently my Air condition unit started giving some problems i changed my compressor, evaporator, pressure switch, the switches inside, and all the relays but the problem persists
the problem is when i start the car whether the AC switch is on or off the AC fan and the compressors comes on and runs non-stop
if i unjack the pressure switch they come off i got the car scanned it came back with two codes 0118 which points to the temp sensor i'm about to change that and another code (u12db) i have searched all over and cant find anything related to this code can any one help
