Two weeks ago my car (137,000 miles) very suddenly started to run rough and then the third cylinder started misfiring consistently, making the car barely drivable. I tried swapping coil packs, plugs, and wires but nothing changed. I then tried to swap the third and fourth fuel injectors to see if the misfire moved to cylinder 4, but I broke an O-ring and decided to go ahead and purchase a set of used injectors cheap on the forum. Shipping was slow and I had to wait two weeks, and when they arrived I swapped out the injector originally on cylinder 3 with a replacement. When I then tried to start the car after letting the fuel pump build up pressure it would not start. It tries to turn over slowly and makes a clunking noise, almost like a knock. It doesn't sound close to correct. Even with the misfire before, the engine would still start and run.
I don't know if this could be related, but I have been burning oil for a while (blue smoke when I start the car). I assume the valve seals are bad but I haven't gotten around to fixing them. Could letting the car sit for two weeks have let too much oil drip into the engine or caused some other problem? I also noticed oil around the intake manifold and on the back of the engine, including puddles behind the intake manifold gasket. Could I have a more serious problem now? I'm trying to figure out why it won't even start today, when it started with a misfire two weeks ago.
I know this is an odd mix of symptoms & problems, but any advice, even just what else to test, is greatly appreciated. I am stumped.
