I have a question:
in the
australian forum I found several statments that regeneration
is also indicated by "I-Stop Indicator" off.
Tell-tale sign for this happening is the i-Stop light being off and a low-pitched hum in the car when you take your foot off the accelerator.
I recall having high fuel consumption and a bit of a burny smell the first (and only?) time DPF regeneration happened (I kinda surmised this to be the case after the fact) – the i-Stop light was OFF (not amber) for the duration.
When fuel consumption returned to normal, i-Stop light was back on
The 'evidence' for me was:
1. burning smell
2. high fuel consumption
3. i-Stop light OFF (not amber)
Only for the Australian version of the car ? Germany: I-Stop green = I-Stop stopped the engine, I-Stop yellow = function switched off, I-Stop light off = function switched on
Is someone able to explain this item. Would be excellent to have 100% indication for testing purpose.
