Hi. I have a problem with my mazda 6 skyactive-d 2.2 150hp 2013 (155000 km). I got several notifications/warnings on the board:
- Vehicle system inspection required
- (few days latter) Low oil pressure + engine inspection required.
When I stop the engine the master warning for low oil pressure is gone. Just the check engine light is on. I assume because an error code was written.
Checked the oil it is little bit above the max but below the X mark.
I drove the car for few more days without any problem. But yesterday I got the same low oil pressure warning few times during city driving.
The error code stored is P055F which is for "Engine oil pressure control circuit low oil pressure. The engine oil pressure is the specified value or less after the specified time has elapsed since the engine was started".
Did anyone have the same problem before? Could it be because of the oil /filter? Currently the car is with Castrol oil with ACEA C3 standard as required by mazda.
The other options I saw in the workshop guide are with the oil pressure sensor wiring, bad oil pressure sensor, bad oil pump, bad PCM etc..
Thanks.
Thanks.
