I have an 07 Mazda3s with the aux. input jack in the armrest console. It works fine, unless I use *either* of the 12V DC plugs to power/charge the mp3 player. Then I get alternator whine and ignition noise (one's a whine, the other a fast ticking that changes with RPM).
This is true whether I use my Archos player with it's 12 V cord (I've actually tried aftermarket adapters, too), or my zut capri Tom Tom 910, with its rather bulky, fancy 12V adaptor. Do others have this problem, or should I take it in (car has about 1200 miles on it!). Yes, I can run w/o charger, but not on long trips. Oh, I've tried ferrite cores on every combo of DC line, audio line, both, both players, etc. Thanks for any help! - Jud
Some additional info:
A friend says he thinks it is a ground loop. He's a lawyer with an EE undergrad and Extra class ham, so he may well be right. But it seems odd, especially if you use the 12V jack that's inches from the aux input. You'd think they'd be grounded to each other or at least to 2 point very close to each other. AS I understand it, ground loop results from potential difference from using 2 grounds with significant resistance (voltage drop) between them,
