Engine light on-multiple dtc's..please help!
ginapic21
2002 mazda protege
I have a 2002 protege and have 4 dtc's on right now and failed my emissions test today.
Hope someone can help with troubleshooting these codes:P0102, 0304, 1250, 1569.
Am I looking at an expensive repair or can I do some of this myself. I should note that I had a rat living in my engine over the winter which has made a mess! I think the stinker nibbled on some wires or so it appears. He is gone now.
P0102 is mass air flow sensor.
P0304 is cylinder 4 misfire
P1250 seems to be fuel preassure regulator
P1569 vtcs issue
I'd start checking wiring none of those are related and highly unlikely all that would go bad at once
Start fixing the easiest and cheapest error codes and see if that clears the others.
I would replace Cylinder 4 spark plug and coil pack. If it's been at least 50,000 miles since spark plug change I would change them all.
Then clean the Mass air flow sensor with throttle body cleaner.
Hopefully this solves your problems.
