Engine Jack Points
wiprotege5
2002 Mazda Protege5 & 2007 Mazda 3 GT
Well, tomorrow I plan on replacing the front motor mount on the P5. I could go borrow a buddy's engine hoist, but its kinda a pain to move it.
Where and what can you use to jack the motor up to change the front motor mount. I saw two potential spots that include two points that stick out from the bottom of the motor and a round hole in the frame.
your not lifting the motor... your just supporting it... should be fine with a block of wood
Didn't use wood between the jack and oil pan when I did it, and dented the pan a little. Not good. You'll be fine using the jack for the front, but I would get a hoist if you're doing the sides...it's just easier.
Awesome sauce. I ordered a Medieval Mortorsports front mount and it should be on it's way. I have to buy a jack though :(.
