gezundheit
Hi, just wondering if anyone has ever seen their CX-5 give off the "Engine Inspection Required" message.  My parents have a 2014 CX-5 Touring 2WD w/the Tech Package so the message shows up on the right-most gauge in orange lettering.  I did a quick search through the online pdf and couldn't find a match.  I don't know if this had anything to do with me tooling around in the fuse boxes (both under the hood and in the driver's side) after I blew a 15A one installing some cabin LED's (since replaced).  I'm fairly sure I put the fuses I checked back correctly and securely (only removed the ones I could pull with the fuse puller, and probably only five of them).  Would that be enough to throw up that error?  Any other tips I could check before I have them book an appointment at a dealership?
