Recently taken delivery of a new CX 5. I believe there is a problem with the engine speed upon start up. On several occasions the car starts in a normal way and tick over at around 850 rpm but then, on others, it will race up to around 1800 - 2000 rpm. I reported this to the dealer and delivered the car to them for investigation only to be told all is fine. I can accept "there are no codes showing" after a diagnostic check but, nevertheless, Mazda can't give me a suitable explanation for the differing engine speeds which occur whether the engine is hot or cold. Surely, the car is designed to tick over at 850 ish on start up regardless of the "outside" temp. I should add that after about 20 or 30 seconds, the engine speed settles to normal tickover. Any advice would be most welcome thank you. Dave
