Engine designations?
mikeyb
Contributor
01 BMW 325xi Touring
What are the engine designations of the 2.0l and 2.3l? Someone I know is arguing with me about the 2.3l is from the Focus.
The Mazda3 & Mazda6 2.3l is the same basic engine as the 2.3l Ford Focus. However, this engine is very flexible (certain performance components can be added or removed), and can also be tuned in many ways. The Focus version of the 2.3l does NOT have VVT but has PZEV (hence lower hp & torque). Even in the Mazda3 vs Mazda6, the 2.3l is even tuned differently (heck the Mazda3 2.3l is tuned differently between JDM and N. American-spec).
Edit: This engine family was designed by Mazda for the purpose of sharing it around the Ford family (Mazda is Ford's 'center of excellence' for 4-cylinder engines). This engine family also includes displacements in 1.8, and 2.0. Because of this sharing, there are plants around the world that produce engines of this engine family.
Do these engines have names? Like Nissan has the QR25DE for the 2.5L 4 cyl in the SE-R and Altima and the VR35 for 3.5 V6.
I don't know the internal codenames, but I do know the marketing names (maybe the internal codename is the marketing name).
Aside from the rotary, all new generation Mazda engines are prefixed with MZR. So the 2.3l is called MZR-2.3l. But MZR doesn't just refer to this engine family, as the Mazda6 3.0l V6 also gets the MZR prefix (MZR-3.0l). So MZR is just Mazda's marketing name for all new generation engines.
On the Ford side, the '05 N. American-spec Focus will incorporate the 2.0l and 2.3l engines and here's the names they use:
Duratec 20
Duratec 20E (PZEV)
Duratec 23
Similar to Mazda, the Duratec name doesn't just apply to this engine family - the root of the Duratec name is from the Duratec 3.0l V6.
Bottom-line, it's all marketing!
mikeyb said:
It makes sense for Ford to share engines with Mazda.
Considering Ford owns a good chunk of them, yes :D the four cylinder is going into another Ford family car - a compact Volvo.
Actually, the Volvo S40 and S50 are using a Volvo engine.
"New Volvo Performance
The all new Volvo V50 is being introduced with a choice of innovative 5-cylinder engines: a normally aspirated 2.4-liter unit producing 168-horsepower, and a 2.5-liter 218-horsepower light-pressure turbocharged T5 engine. "
from http://apps.volvocars.us/V50/press1.html
hmmm...i had read in the past months in road and track that both the next focus and volvo compact were going to be mazda3 clones in most respects, engines included. if thats incorrect, then i humbly retract :)
You're right and wrong.
World-wide, the Mazda3 has several engines available, some of which are not available in the various markets (e.g. smaller displacements and diesel not available for N. American Mazda3's). The new Volvo S40 is similar. In N. American-spec, the new Volvo S50 won't have this Mazda3/Focus 4-cylinder engine family. However, in Europe, one of these engines will be available.
In the UK anyway the 05 Volvo S40/V50 will have the 2.4L and 2.5L 5 cylinder engine with an optional 2.0L 4cyl turbo diesel engine. All will come either with a 6spd manual or the optional automatic. Also there will be a T5 turbo with AWD.
I found this information on http://www.volvocars.co.uk
The 2.3l in the Mazda 6 line is called the MZi motor by Mazda and the 3.0l "S" motor the MZr. Thats all I know. I will go see if there is anything on the car.
Turbo 3 said:
Doesn't the new base Ranger have a 2.3 DOHC? Are they simular?
Its a 2.3L but its different from the 2.3L in the Mazda 3 and Mazda 6. Its setup for RWD not FWD. The 2.3L in the Ranger have been out for years. I had a early 90's with the 2.3L Theres also a 3.0L V6 in the mid range Rangers. Wasn't there also a 2.4L in the Ranger?
