Engine Damper Comments/Qs
Hey Chris,
The holes in the L-bracket match up perfectly, but the damper itself didn't bolt up at all.
http://www.msprotege.com/members/L8R/Damper-17.JPG - If i bolted the L-bracket in properly, the damper is too long (old picture, but same problem).
I just had to widen the holes at the base of the mount to allow a little room to move the L-bracket on the motor mount. I have no problems with it now :D I suggest instead of circles drilled to fit the motor mount screws perfectly, it should be ovals so at least you can move the L-bracket a little, just a suggestion. Like I mentioned, I could careless at this point because I know you guys (at weapon-r) tried your best to fix the problem, and I thank you for your swift actions. No complaints now. I just suggest maybe for future sales you make the holes wider.
Joka-Thread responded too.
Peace
