Engine Bolt Torque Specs
OrangeAppeal
'03 MSP - #729 - '90 CRX Si
Looking for the torque specs and sequencing for rebuilding my block...can someone lead me in the right direction?
Ideally I would like a source for all torque specs for the block, but at hand I need the Rod Bolts, crank braces (what holds the crank bearings in place), the crank girdle, oil pan, oil pump, and covers.
Thanks in advance
-Jesse
Note: I tried a search, but was overloaded with unhelpful info - the online service manual doesn't have this info either (which I found weird?)
update: Found the info, the torque specs for the oil pump bolts, crank girdle mounting bolts and oil pan mounting bolts are all 14 - 18 ft-lbs of torque according to the service manual in the lubrication section of the engine chapter
