Engine bearing clearances help
slowwpro
slowwpro
03 Mazda protege es
Looking for some much needed help. I'm changing out my main&rod bearings in my 2003 Mazda protege. And I can't find any legitimate info on bearing clearances online anywhere.
I went with the less accurate route and used a plastigauge.
And here are the numbers I got for the main caps #1 being pulley side of motor.
#1--(.0015")
#2--(.002")
#3--(.002")
#4--(.0015")
#5--(.0015")
So I'm almost positive these numbers are incorrect. If so how off are they and what should I do to fix this. Somebody please if you have the correct specs for the 2.0 fs. Please help me out here.
I also need the specs for the rods & the THRUST washer
I plasigauges one rod cap an it was at(.001") not sure if that is correct either.
Thanks for the help.
Latest posts
