I assume dino meant the radiator mount? If so, that is the rough draft version for a replacement bracket that a buddy of mine is making. He is on here, his SN is crazybassmp5 I think. The finshed version will be a little wider and will be rounded off. Pretty sweet little cap IMO.
The vac lines haven't shown any signs of melting. Apparently the hosetechniques silicone is VERY good. The only spot that concerns me a little is the outlet of the DSBC where it goes down to the wastegate actuator. That is by far the closest that any of the silicone is, and I definitely don't want to have a leak right there and cause some overboost or bootstrap. I ran the car pretty hard for 120 miles straight last week, and then inspected everything around the manifold. The o2 sensor harness is right there, and so is that one vac line. Both looked totally fine without even a hint of melting after that trip, so I think it should be ok. I will monitor it closely when it gets real hot here again in a few months.
