End all Protege Transmission Thread.
I have a F25M-R transmission with my 99 ES 1.8L, and I am officially starting my research on an LSD after I put in my turbo. Nothing like being able to put the power down. In any case, what is available for my model year and transmission?
.... explains why i lost the clutch and tranny out of my 2002 P5 within 9 months. And than after they warrantied the tranny, and not the clutch there were no problems. But to be on the safe side I put a ACT H/D street clutch with a 9 lb flywheel in. What a grabbing difference that made.
ROB-80E said:
Not a match for me. (sad2) That's on both sides of the diff is it mate?
I counted the splines from the passenger side jackshaft... I can double check the driver side halfshaft tomorrow for you.
Thanks!
Steve
You're probably doing it right, but it's the raised spline count we're after, not the pits.
Both of us are very confused over a 29 spline count.
Yep.. was counting ridges not pits... I'll count it again.. I was confused by it as well... I was tired as hell so I counted it 3 times and got the same thing every time.. I thought it should have been 30 or 28.. but not 29.. but dunno! I'll photo it for you too and that mayhelp.
Later,
Steve
Shouldn't there always be the same number of hills and valleys? If there wasn't, two valleys (or ridges) would touch each other at the end of the count.
yep that's right. Generally easier to mark your first ridge and count round so you know where you started.
Thanks again for all your effort on this one steve....appreciated. ;)
TurfBurn, a response, please? Even if it's to say buzz off.
Glyph... not too much of an idea... take a look aroudn though and see if you can find the FAQ that may have the info you need.
Sorry I hadn't seen your question before!
It looks like I miscounted... I recounted and I got 28 today.. so dunno.. .here are the pics.. knock yourself out recounting them!
Later.
Steve
I got 28 too, but I only have 10 fingers to count on, so take it at that.
(10)
(bowdown)
(cool) (headbang) (mj) (nana) (yippy) (drinks) (alright) (dance)
I think that sums it up. :D
