thats the problem knox joe,A SS AFC V.3 with a good dyno tune, and tuner, should be able to get the timing right.
1.) They don't know MSP's!!! lol
2.) They don't know about the AFC's available for our cars.
3.) Don't worry about that. As long as they have that tool to detect knock, then you're set. If that thing triggers, that's where you have to pull timing. I'm sure there's more to it than that, but it should be the basis of your tune.
2-they told me AFC's dont come with timming control.(beer)
im not saying he wasn't right.. but its not the route i want to take..Ha, funny thing about that is I work for Labonte MotorSports. We specialize in water/meth injection kits. In some ways, the guy was right![]()
You'll generally want to pull timing between 3500-5000RPM (you need more up top, because the combustion event happens so much faster) and DO NOT take it to that shop. Their "knock device" sounds just like a knock light. No big deal. Look around, you said you're close to Q City, there's gotta be some shops there. Don't be afraid to drive a bit for the sake of your engine.
I agree. I wouldn't run 14 psi in my own MSP (Even with water/meth I would be paranoid about it. I'll wait till I'm forged) so I wouldn't recommend someone else do it with theirs.
fr0st, if the guys at the dyno shop have a good reputation for doing work on other cars, they probably do know what they're doing, they just don't know the specifics about what you are doing.
Tell them that the AFC has piggyback timing control and explain it to them. They may not know specifics about the Mazda, but motors are generally the same, and if you can explain the idiosyncrasies of this car has, they may be able to at least do a light tune to get you to Quebec, or if they're good enough they can get r done.
surely i can go around with 9 psi and stock ecu richness so i can make to quebec city without asny problem?
Definitely, I drove around on an untuned AFC, with FMIC, exh, intake, etc. I was running 9.5 psi with no boost controller (boost just went up that much from supporting mods).
No problem, just runs rich in boost, not so bad though.
you say pull timming from 3500 to 5000.. what happens after that? you leave it stock? or pull LESS timming than between 3500-5000 ?
can i go around with the stock supermap already in the AFC and 9 psi?
if so, then im golden. i'd rather go directly to a place where they already know msp's and will be better equipped as they get alot more cars to tune.
I don't know. I have a full standalone, which is still the way to go. Piggybacks are a waste of money IMO
Yes and no, tuning a car with a full standalone for cold weather starts can be difficult and may require adjusting throughout the seasons. They are great if its always hot or consistent in temperature.
