Eliminating Flutter Dump
Sledgehammer
Mazdaspeed6
Im having bad flutterdump from my speed6 at full boost let off. Mods include PG SRI, Forge BPV (blue spring 1 shim). Anyone have a good way to eliminate this?
Try lubing up the forge real good and just run the blue spring with no shim.
I get the fluttering sound when my forge gets a little dirty and needs some lube.
I used grease on mine when I lubed it. Take it off the car first to see if your o-rings are shot. Press the cylinder up all the way and put your finger on the vacuum port holding it shut. The valve should not close. If it shuts your o-rings are bad. Forge website sells a rebuild kit.
