Electric Window Problems
Both passenger windows "front and back" stopped working? when I bought this 2007 Mazda 5 there was a problem with the rear passenger window but now both don't work either from the driver door or from the actual door. Has anyone had this problem and if so what was the solution. Thanks
Check the fuses and once working press down holding the down bottom until window reaches the full down position. That should reset all the switches.
The contacts inside the switch get carboned up. I went to a junk yard and picked up a new switch.
I previously took apart the switch to clean it all up, but it didn't last and the window switches failed again.
