Like NOS, the ESC400 is designed for short burst use, but unlike costly Nitrous refills, a high-output 200-amp alternator upgrade (not included) will fully recharge the power supply after only a few minutes on the road. By installing a SDPT switch, you can protect your alternator while your system is running and recharge your power supply while you drive.
A fully charged battery set will yield a number of runs before recharge is necessary. We recommend Odyssey racing batteries, which allow for extremely quick recharging. Standard automotive batteries are limited to a charging rate of 30 amps, which means longer charging times. A standard alternator is approximately 85 amps. A standard automotive high-amp battery charger will recharge the Oddysey batteries in less than an hour. The ESC-400 draws 1250 amps, so at 100 amps the recharge rate ratio is about 15:1.
Warning: you must upgrade your alternator to a 200+ amp unit. Attempts to recharge off a stock alternator will cause overheating and possible damage!
Thomas Knight uses and recommends the Odyssey 680 racing battery. They weigh only 15 LB each and hold 680 AMPs.
http://www.odysseybatteries.com/
