Electric exhaust cut out
I honestly don't see the point in it for this car, other than some noise. The only real place you could put it would be where the midpipe is or behind that, and at that point you might as well just get a catless midpipe or something. The stock cat back isn't very restrictive. Some of that restriction is actually good with the stock turbo because, with a very free flowing exhaust, it will actually start overwhelming the wastegate and you will see boost creep. A lot of people (including myself) who removed both cats already see that.
I guess it depends on what your goals are for that piece. If it's to make a bunch of noise or if it's in the pursuit of more power.
The stock CBE flows better than the output of our stock turbo. A cutout would only be like a test pipe. Otherwise you are just spending money on a cheezy loud noisemaker.
Don't get me wrong, now. On some applications, especially normally aspirated big high power V8's with long tube headers, cutouts right after the header collectors can make some serious power gains over most muffler systems.
I had a muscle car with a highly modded small block MOPAR engine that probably was putting out close to 500 crank horsepower on pump gas. I used to have fun at stoplights when some idiots with loud car stereos would pull up next to me forcing everyone within three blocks to listen to their "music" whether we liked it or not. I'd just open the cutouts and raise the engine rpm to about 6k and hold it there. You should have seen the look on their faces. Absolutely impossible for them to hear their own music inside their own car.
Still brings a smile when I think about it.
But you are right that this is obnoxiously loud. And use is a cop magnet. And for our cars on the stock turbo, it just does not work any better that a simple test pipe. Further, a straight exhaust dump on a four banger engine sounds horrible anyway -- more like a farm tractor than anything else.
