eibach pro kit and koni
baczuse
Hello evey one i need some help but i was wondering if it is a good idea to put koni sport shocks and the eibach pro kit on my 3, and what will the ride be after stiffer then the stock or about the same. Also will i need the camber kit because i do have 18in on the car. thanks
The ride would be stiffer, but it would also handle almost like a go-kart. As for camber, it all depends on what the alignment does AFTER you install the springs. You should be alright with the Pro-Kit.
