If I lower the cooling charge, won't I get more power at a given engine speed (and in our case, a given gear)? That way, if I assume I'm cruising at one speed with the stock IC and it requires a specific power demand to keep that speed, which has some associated hypothetical throttle position and gear. Then, if I switch to the new IC and my charge becomes cooler and thus the air is denser, won't the O2 sensor then respond by increasing the fuel delivery, thereby increasing the power output and then the car will accelerate at that given gear, throttle position, and speed?
So to keep my cruising speed I would have to back off the throttle.
I would think that's the same reason a CAI increases fuel economy- the pumping losses are reduced and the charge temp is reduced so you get more 02 in at a given set of conditions- O2 reads this, ECU has to deliver more fuel to keep the cat in its window of efficiency and so you get more power. Again requiring us to back off the throttle.
What's the functional difference between a better IC and switching to a CAI? I feel like I'm missing some bit of information, or I have some major misconception. (stash)
Again, I am just trying to think this through and make sense of it. I'm responding only to try to grind out an understanding on how this all works. (braindead
