Not exactly good practice to break the rules and try to hide it. I also forgot about the MegaSquirt. You can control fuel and timing with it and would probably be a fairly good option. A friend of mine was wiring one up for his Grand National and was testing it with his turbo Integra. Not sure how it's worked out so far, but I've heard good things about the system.SirJaime said:yiup yiup, all about the class's. you want to hide what you can. If they can find it, its a good up grade.
I e-mailed these guys and it won't work our set up yet. They said they are working on something for a November release time. I'll keep you posted because this is what i'll probably end up getting.speedfrk said:http://www.sctflash.com/
Email these guys they have done mazdas and are the best solution for the ford ecu that our cars have .
This man speaks the truth. Although with the SCT Software you'll have control over your actual ECU so you won't be wondering if you have everything wired right or if your ECU is learing around it. You'll also have access to all the stock ECU's parameters, as well as being able to monter all the stock sensors so you can see everything happening to your engine. It's a built in scan tool so you can see everything and also read codes. If you're racing and you know what you are doing when you tune then something like this is what you'll want. You can also get it with a built in 2 step rev limiter, which would help you greatly it you have standing starts.apocman said:MPI, UniChip or any other piggyback unit should suit your needs. Just make sure that it has been proven to work on your car before you purchase or you may be in for more than you bargained for.
Mallard said:This man speaks the truth. Although with the SCT Software you'll have control over your actual ECU so you won't be wondering if you have everything wired right or if your ECU is learing around it. You'll also have access to all the stock ECU's parameters, as well as being able to monter all the stock sensors so you can see everything happening to your engine. It's a built in scan tool so you can see everything and also read codes. If you're racing and you know what you are doing when you tune then something like this is what you'll want. You can also get it with a built in 2 step rev limiter, which would help you greatly it you have standing starts.
This is the option I am going with, if it indeed comes out in November like they said it would. I will continue to be in contact with SCT and keep you posted on the progress.
