i went to my dealershit and they said nothing new was out, but they will hook up and check for updates. and it would be "like around 40 dollars" .
am i gettin jipped?
What is your build date? From my reading of the TSB, it appears as though your dealer should always replace the fuel pump if the car was built before 4/7/2007 and the fuel pump's manufacture date was before 3/26/2007.
For cars with the older fuel pump, I'm worried that an ECU flash without the fuel pump upgrade is going to cause problems...
if you're under warranty they shouldn't be charging you anything. This is covered by the factory.
