Ecu question
ti-ben
Hi
I have a protege 2002 2.0l N/A and I've bought a turbo kit from a Mazdaspeed 2003. I was wondering if I could just plug and play, considering that I have everything (turbo, hoses, intercooler, ecu, exhaust....)
Are the timing and compression the same, and will the msp ecu work with my setup. Do I need anything else??
what is the safe limit for the boost pressure.
Thanks.
Ben
the msp ecu is plug and play to your wiring harness. you will need to have the mazdaspeed's ac compressor as well as plumbing for the turbo oil lines.
AC (air conditionning) compressor ? Why do I need that.
