Easy question about rims
Je5ter
2007 Speed3 CWP FTW
I'm assuming a 18x7.5 with a bolt pattern of 5x11.3 and offset of 45 will fit my speed properly without any fender rolling or that crap, and will I have any problems when I lower it with either Cobb springs or H&R sports (if I can ever get them)?? Oh and will my stock tires fit? I just want to know for sure before I purchase them and not have any problems after the fact...Stil pretty new to this whole mod thing. Thanks!!!!(thumb)
you might wanna check the size of the hub bore of the rims you're getting, the speed3 is 67.1 mm, you might need some hub rings and yes the stock tires will fit on the 7.5" rim, oh and you shouldnt have any problems running that set up with the cobb or h&r springs
The rims I'm looking at have a bore of 72.6mm... No go?? Or will I need spacers? I"m pretty sure the spacers come with the rims from the site I"m buying them off.
You can get by without hubcentric rings to fill in the gap between the hub's 67.1 and the wheel's bore of 72.6, but only if you torque the lugs in the right order and settings and with the wheels off the ground. Doing this will center the wheel on the hub, but it's just easier to run hubcentric rings. They usually go for ~$25 if you need to buy them separately.
