Dyno Tune Results very happy
its a dyno, they are anything but accurate based on overall output. Go to the track and see where it traps.
If anything this is proof that all you need is a boost controller as the a/f ratios are still safe and i highly doubt he added fuel. Save your money, unless you want to be able to tell people, yea im using an ems as a boost controller(dunno)
also make sure to frequently check you a/f ratio as they will change with weather.
You don't let up do you?
Congrats on the numbers. Impressive for sure.
BAD NEWS!!! i got one run in at the track and then my 3rd cylinder started misfiring. turns out i melted a spark plug. had to call it a night really early.
the one run i did get in i ran a 13.812 but i bogged down and my 60' was a horrible 2.4!
All I need to get to the track is to either lower my boost or upgrade fuel pump (to remove fuel cut), and strap my dif so I can get a decent launch.
My best 60' is a 1.9, ran a 13.68. Supposedly if I did a 1.7 I should have ran 13.3-ish.
Once I get my car tuned in-town at CFT, I hope to get around 350whp or so at 17psi.
so what happen to him going to the track? Let me guess he trapped 102 mph and doesnt want to post about it?(spank)
If you melted a plug, that is NOT a good sign. You are running way to lean and you need fuel!
