at 90%VE, 2.1bar, 2.1L at 6500 his motor requires 32lb/m airflow... 2860RS even in the larger AR operates at 34-35lb/m max (at 60%) for that PSI. upping the boost just makes it worse from there.Say what?? Out of it's efficiency at 16psi... as in causing detonation or not making more power by upping boost?? Any idea of your egt's??
Ok I'll have to look into that, the car is parked at my parents for now but in the spring I'll change it.Kirk, had a feeling that turbo would hold you up a bit.you'll have plenty of headroom on those injectors. Run the stock FPR without the solenoid, just run the vac line right to it. Set the HALTECH up for sequential, and if you start running out of headroom, try changing the injector phase timing first without upping boost or injector time and see where it gets you before you change anything else. The stock FPR is rising rate, so your fuel curve will be parabolic, not linear.
Ps where are you having it tuned? That guy in red deer?
did you end up asking the guy what the fuel pressure and duty cycle % the injectors were running when you made the pulls? sounds like a beast congrats! you must be very happy!
