+1
I've only been able to get the rear end loose once, and it wasn't the greatest feeling in the world...
I was more concerned with not spinning out, but I'm fairly certain it was off-throttle, snap oversteer (in the middle of a slalom on a slight grade.)
The biggest bang-for-the-buck improvement you can make is tires. After that, you need to tune the loose nut behind the wheel.
Do y'all turn traction control off when you are autocrossing? I tried it for one event last season and my tires sounded really pissed. Any preferences?
Drag launches will gain grip with lower psi. However with lower psi you lose lateral grip. This is becuase the contact patch deforms when the sidewall flexes. This is true up untill a certain piont, rock hard tires will not do anything properly. Knowing this you can change the balance of the car much like the effect of sway bar adjustments.I know when you turn off the stability control, the MS3 really likes to oversteer. Really felt uneasy when I tried it, but definitely if I could have had more seat time with it, I could have started to swing the rear end.
I thought you had to increase tire pressure to make the rear swing out and lower tire pressure to increase traction...right up before the point sidewalls start giving out.
I wouldn't want to roll my sidewalls and blow a tire...
The traction control intervenes way to early on these cars for AX. You guys really gotta turn that stuff off. The tc dos not allow for proper car control. I find it is to intrusive for daily driving, for AX you have to turn it off.Do y'all turn traction control off when you are autocrossing? I tried it for one event last season and my tires sounded really pissed. Any preferences?
Anybody try messing around with tire pressure yet?
Its the same process... Traction Control can be turned off just by pressing the DSC button while the car is running. And press it again to turn it on.
To disable stability control, you have to press the button before turning on the car and keep it pressed till the two lights turn on/stay on.
To turn it all back on, just press the button once...
The settings will always reset when you turn the car off...
Think you have it backwards. You turn off DSC by pressing the DSC button at any time. Traction control you have to hold the button down during startup. When traction control is off you see the light that looks like this (drive2)
The way I see it DSC is your turning traction. It keeps your car from skidding aroud corners (which is bad for trying to rotate the back end)
Traction control is more for keeping the wheels from spinning when accelerating or changing road surfaces.
The lights on the dashboard are inverted...
I know on my 2008, pressing the button any time will disable the traction control. Doing the hold before startup and shortly after, will disable stability control.
How does your MS3 class in STU...?
My local SCCA club says I only fit in one class...DSP.
What classes does the MS3 qualify for?
The lights on the dashboard are backwards...
I always thought the dashboard lights were a little misleading...I think they are backwards...
