goldwing2000
Mazdas247 OG
- 2018 Mazda6
2004 Mazda3 (sold)
2024 CX-5 (sold)
Understood.
{/threadjack}
{/threadjack}
Karma_hunden said:So the MSP3 dont adjust entirely? hmm...i already had my sight on one. Gold, arent your tires getting it since you dont have camber links? When did you intalled the springs?
I wanna know how you did that!goldwing2000 said:The Speed links will get you about 1.5 to 2 degrees of camber.
No... my tires aren't getting hit. I... uhhh... modified... my stock arms to work temporarily. (shady)
tphskab said:I wanna know how you did that!
goldwing2000 said:I'll bet you do. I'm not gonna tell, though. If somebody were to do it wrong and screw it up, it could have serious, life-threatening consequences. I'm not going to put myself up for that kind of liability.
Sorry. (shrug)
Suffice to say that it can be done with a little imagination and a die grinder.
hmmm.....sounds like a lot of work.......goldwing2000 said:It would be difficult. It's a 3-link system with a single upper link and double lower links. The rear lower link is the toe adjuster, so anything you did would have to be to the forward link and then hope there's enough adjustment in the rear link to compensate.
Anything is possible, given enough time and money.
What about having your offset cut down an additional 3-5mm? Where is the company who did it the first time?
i know, but the shop that did it was somewhere in the east somewhere.....I dont remember where....I wanna say tennessee. I dont wanna be without my rims for that longgoldwing2000 said:Call the people you got the wheels from and see if they can hook you up!
yeah, I dont think another 3mm will do much to the integrity of the wheel. I havent inspected too thoroughly, but it appears to be pretty thicktsunami said:yeah Phil any good machine shop should be able to do that, they need probably a cnc, i am not sure if a regular milling machine would be able to handle a full wheel and have enough clearance. and i can't see a lathe being able to do what you want. also with you taking off that much material you are starting to bring the integrity of the wheel into play. take a measurement of the thickness of the center before you get to carried away.
