Ok peeps, I've run a search and nothing I could find on this subject...many tire pressure suggestions for 1/4 mile, but no daily driver info.
Here's my problem. In July, I dropped my P5 with ION Sport Springs, so almost 1.2" around. Obviously, as was noted at the time, the FR of the car has a lean. Anyhow, I've noticed that my stock rims/tires seem to look flat, underinflated, but when I check the tire pressure, it's at 32.
When you drop your car, is it normal for this to happen? Should I inflate to a higher PSI? The tire says max PSI 52 or 55 I think. How high should I go. Any recommendations from people who've dropped their cars? Are you still running the same pressure as pre-drop?
Much thanks,
Haig
Much thanks,
Haig
