- 1989 RX-7 GXL Blaze Red
Yep. And there's a mild steel specification too I'd bet. Mild steel can be MIG welded effectively, 4130 should be TIG'd. Mild steel has a lower carbon content, making it far less prone to cracking. In terms of crash safety the added strength doesn't buy you anything. In terms of chassis stiffness they will be the same; or better if the rules spec a thicker mild steel sidewall.
You'll have to argue that with them then. I can't sway anyone. We specialize in Tig'ing here.
