With OP's mods, a downpipe is the next logical step, provided he has a way to constantly monitor boost and provided he has a way to keep up with what his engine is doing with AFR's and further provided he has no fuel pressure issues. But that TurboXS race pipe would love to be connected to the TurboXS catless downpipe!
Since he already has a good intake, a race pipe and a bigger intercooler, he's ready for the dp. Yes, it's a b**** to install, but well worth the extra effort.
With the bigger IC, he probably needs to look into either a custom AP tune or at least a pretty advanced multi function real time monitoring and logging device like Dash Hawk.
I do see that OP is running a dual port BOV, apparantly set 50% bypass, 50% VTA. I say that's not good for this engine and will contribute to running richer and losing some power, especially right after a shift. If OP thinks that running 50-50 solves the drivability problem, maybe so, but it does not solve the fact that oxygen is escaping to atmosphere that the MAF and ECU intend to be burned during combustion. That's lost power. This engine needs pure recirculation, whether you have a true BPV or a BOV.
A downpipe is a serious mod, that builds serious power. and requires a serious level of attention to make sure OP stays safe.
On stock tune there are enough safeguards in place that as long as sustained boost does not go above 18-19 psi, OP will probably be safe, because under potentially harmful conditions, the stock ECU will probably reduce boost, pull timing back, slap him down with fuel cut or all of the above. That's not a bad thing, IMHO. While unwelcome when it happens, fuel cut is your engine's friend.
He's probably at the point in his mods that he should be knowing what his fuel pressure is and that also means Dash Hawk or AP.
He'll not realize the full potential of his car after the dp addition to his existing mods without a tune, but tune can lead to either bliss or zoom, zoom, boom, especially if boost is taken over 18 sustained on the stock turbo or AFR's allowed to get too lean above high 11's, or the stock safety mechanisms bypassed in the tune, IMO.
I say OP should drive what he has another 5k miles but with good monitoring in place and get used to what his car is doing now before stepping up, but then go with whichever downpipe he can do where he lives (catted or catless) depending on what he has to do to pass inspection.
