door panel removal
oldtruck
do I need any special tools to remove the door panel of a '92 2200 truck. I'm replacing the window on the driver's side.
Not to many people on this board have a 92 truck...but I'm going to guess and say that all you need is a phillips and flathead screwdriver. If you don't have power windows I think there might be a special tool to remove the window cranks but sometimes you can pop them off with a flathead screwdriver.
I just took one of the panels off of my '89. I'm pretty sure it's the same truck. It was easy. There's a little snap ring thing that holds the window crank, but it pops off easily enough. Everything else is just phillips screws.
