its my understanding that recent uncoverings are the problem with torque. to much to early in the power band. the mzr disi makes a buttload of torque so suddenly it can bend/brake rods. tuning would be key to push the the powerband back a bit.
you could get into the direct injection and its crazy psi. correct me if i'm wrong but its as high as 1500 psi and needs to be even higher at higher rpm and higher power levels. thats why the external hpfp needs upgrading after certain power levels to keep up.
and again i could be wrong but thats ultimately the limitation with the fuel system. not that its inadequate but that it requires so much pressure in order to do its thing.
now this should get blendercloud and tunersteve rolling with the punches!!!!
