Does anyone have Time Attack style wheels on their MS3?
A week or so ago I bought these rims for my Civic SI -
However, things aren't working out with my civic (2nd gear is near-impossible to now shift into at 6k+ RPMs) and my dealer is refusing to acknowledge there's a problem. If the next dealer I visit can't fix the issue, I'm trading it in on an MS3, since a few talks with a salesman showed that it would be easily affordable to do.
If I do this, I'm most likely going to get a black one, black out the windows/lights and then put these wheels on there. They're 17x7, 45 MM offset, 5x114.3, which I'm assuming (but don't know for sure) will fit. Sorry for all the rambling, basically my question is does anyone have wheels like these on their MS3, regardless of the car's color? I searched the thread showing them and couldn't find any..
Thanks for any help.
I'd check the center bore to make sure. Everything else appears to be inline with what people are using for 17s on the MS3. I think the center bore is 60ish mm?
I was just starting a search for the same thing. I'd like to get a set of Rotas, possibly SDRs on my black MS3.
The bore diameter is 67.1mm
When did Civics start using 5-lug hubs??
The bore diameter is 61.7
the newest generation of civics are all 5 lug
whats the weight and cost of those wheels?
Some people are saying 19 lbs, but according to fed ex it's 17 lbs.
They were $550 shipped to my door, including the wheels, caps and hub rings. I also added on some Muteki tuner lugs for about $30 as well, in black. I was hoping someone had them on theirs already because I love the TA color scheme =)
I'm not sure on the center bore.. but I do know they need the hub. rings for a perfect fit on the Civic. And as said, all the new gen. civics use the 5x114.3 pattern.
where did you buy?
