Do Toyota wheels fit Mazda
mangelwurzel
Mazda 5 Furano TD (143PS)
Hi All,
I have been offered a set of Toyota steel rims which I might use through the winter with snow tyres.
Does anyone know if Toyota and Mazda use the same fitment?
Cheers.
Toyota typically uses really small hub bores- ours are 67.1mm. Larger bore wheels = easy fitment, smaller = need a spacer.
It depends on which toyota the steel rims is made for.
Som of the new'er toyota models also use 5*114,3 and the same center diameter but you also have to check the offset, but if you told us which model the toyota rims are made for it would be much easier to answer you.
New Threads
