You can run a car for an hour or more during daylight hours on a fully charged battery.  To do that you must not use anything that consumes power but the engine. You can ruin an alternator by removing the positive battery terminal with the engine running. You could do that on old cars with a generator.
The corrosion on the battery terminals should be cleaned. Usually the alternator isn't charging when the battery light comes on. Most alternators are rebuildable, if it has been in a fire or major parts or broken it may not be rebuildable.
Clifton
Clifton
