not to get off topic but what made you think that? did you hear it(detonation) i seriously doubt anyone couold hear detonation at that psi? what i mean is if your knockin at such little psi there would be no audible sounds...now if your pumpin 18psi well that may be a different story.ARunto said:I would recommend getting the flash...I will be getting mine flashed. After being on the dyno...I noticed the hesitation. Also I had some pinging at high RPM 9psi so I'd keep the boost at a 8 psi.
DiscreetSpeed said:not to get off topic but what made you think that? did you hear it(detonation) i seriously doubt anyone couold hear detonation at that psi? what i mean is if your knockin at such little psi there would be no audible sounds...now if your pumpin 18psi well that may be a different story.
but how do you know?
your telling me you can hear detonation.....dude sometimes a person could be runnin and be detonating without a hint.wicked said:you can have detonation at 0 psi and slill here it but that little ping will be the death of your engine,it will put presure on the center of the piston till it colapses
i would take precutions first
dude so much noise comes from the engine its impossible to hear...especially at those rpms my friend...if anything check your plugs, theyll be the first to show signs.ARunto said:The sound is not knock. It was definitely pinging at 9psi. When I set boost at 8psi the ping would go away. It was very audible on the dyno but not on the road. This was at high RPM range only 5000-6500.
can you tell me what they looked like, pretty plz?ARunto said:the plugs did show signs of detonation (which are NGK BKR7E's)....and dude you can hear it. BTW...this is on pump gas 93 Octane
thatll do it....2 gallons of 104 octane man....makes a car feel good.ARunto said:You can see the insulator and electrode had specks on it.
DiscreetSpeed said:thatll do it....2 gallons of 104 octane man....makes a car feel good.
(bow)coolARunto said:This I know I run 110 leaded & 93 unleaded mix at the track. I would have dynoed it with this setup but my filling station was out of 110 leaded.
