I spent about 15 minutes looking at the different ones in the Irrigation aisle & another 10 minutes discussing what I wanted with an employee. This guy was an expert on irrigation, but I didn't explain what I was doing & I don't think he had any concept of using it for automotive purposes. I bought 2 different kinds & the first one I tried was perfect. I can the bag for each of the components in case anyone wants to pick them up at Home Depot. Ironically, the description on the back of the nozzles I got almost sounded like it was made for IC sprayers, which is why I got it.mx3ownzj00 said:Looks like mine, except I still need to snag a nozzle.
Mine isn't all that advanced...the valves are the only thing that stands out. Otherwise it's just a hose with 2 nozzles. I just really like the way that it turned out.mx3ownzj00 said:ha, I just went to the autoparts store and found the T fitting and hose. its pretty ghetto.
Do your wipers work at all?? If they do, then there you go there is a relay somewhere for it and an alternate path from the regular wiring for the wipers (no matter how small it is).jesse said:My wipers dont go off when I spray the fluid on the window. So if someone knew whats wrong with my car they could do it to their car.![]()
I'm kind of busy during the week, but I will figure it out this weekend.Black Majik MSP said:Can anyone with some electrical expertise help us figure this one out?
Well, right now there isn't much heat(in monsoon season), but every 2 days or so it reaches around 105F. I like to go driving during the day and I do romp on it.arlsmazdaspeed said:lol, your spraying your radiator? (uhm) unless you drive your car in 100 degrees plus weather and romp on it, i don't think its gonna be worth it.....
If you live in AZ, you should be able to do the same thing as us here in FL...jeffmsp said:umm not sure on this one, but since the rac is much much hotter than the IC wouldnt spraying it with cold liquid cause damage?.....I would just look into getting some water wetter additive to help keep the coolant temps down.
Black Majik MSP said:If you live in AZ, you should be able to do the same thing as us here in FL...
Drain your radiator & coolant lines, pour in a full bottle of Water Wetter, & fill up the rest with purified/distilled water. There are many other things that can help with engine temp, but that will probably be your best bet now. You can also try to get someone to produce an intake manifold spacer (AKA phenolic spacer) for the Mazda 3.
Spraying a radiator probably isn't a great idea.IllBinfrontofya said:Sounds great to me. So I'm guessing that i should take the misters off the car, since they really don't do anything anyway?
Also, when draining the radiator, can't you just unplug it from the bottom, and then all the fluid will leak out on its own? Or do you have to also dissconnect all the hoses and so fortyh to get all the fluid? Because my MZ3 has TONS of Fing hoses!Thanx Black Majic
