Disable Power Liftgate on 2022 CX-5
You can open and close it all day long manually just by pushing and pulling. It can't be that good for the motors though. Amazon has a variety of "manual" struts at amazon prices. They are real easy to remove.
and as far as i understand once i disconnect trunk struts motors, lock stops working and it wont open at all
I don't see why it would work like that. The base model doesn't have motors in the struts. The power struts have a simple plug on each one. You can test it by unplugging them. Plugs should be in the upper corner just under the headliner
