I get what you are all saying. I know its rare for injectors to clogg. But on the other hand, the fact that I did get bad gas and they took it to a shop to 'fix' it as it completely shut the car down (i really don't know what they did but I know they didn't do it right. Sounds like all they did was blow out the line) Anyways, one of the reasons I tend to think it could be a clogged injector is because of this. I never had any problems but from the moment I left the shop I got a CEL, which is the misfire Cylinder 1. Its been very awkard in its sympotms, for a while it only seemed to misfire in the morning during startup until it was warm then didn't misfire. I was kinda gettin on it the other day when it started misfiring worse. Couldn't it be possible that the bad gas caused varnish build up, and the other day perhaps the varish just got more clogged in the injector and thats why its misfiring more now? I'm not saying this is the case im just wondering. I would just find it hard to believe that I had no problems, got bad gas and then instantly had bad wires, bad connection or electrical (although i know weird coincidences can happen with cars). BTW, I did replace the coil on cylinder 1, along with plugs to all cylinders. Didn't fix anything.
