dip stick
tprouty
2001 MP3 LASER BLUE MICA
I found out my dipstick is broken inside my oil. is there a way I can get it out without having to go to the dealer?
hmm probably. There's like a 10mm bolt that holds up the tube/stem that the dip stick sits inside of. It's right up near the valve cover right where the dipstick handle is. I know there's something else holding the stem on though, I don't think it can just be lifted out then. I'm also not sure if the oil level is high enough that oil would come out if you removed it.
is it broken at the top were the handel is or deepdown in it if its at the top use a pair of needel nose players if its at the bottom pull the whole tube out.
